Release notes:
- Software 1.0.010 / firmware 1.3.050
- Added Spektrum Binding in software
- Cyclic Rotational Speeds are now separated for Aileron and Elevator
- Overspeed after spoolup with some ESC: fixed
- Dynamic headspeed management during extreme overspeed maneuvers added
- Random hot start on startup on some ESC: fixed
- Governor precompensation optimization
- Added tail drag precompensation
- Added Cyclic Pitch Pump
- Added swashplate design in radio setup for see the servo number position
- In wizard (panel 7) doubled the resolution in swashplate setup
- Factory default "Tail Dynamics" is now at 6% (easier on TT transmissions)
- In Model Size Selection (panel 11) Elevator preset D Gain raised
- Governor: Deadzone range raised now at 0-350
- Bailout ramp range raised now at 0-140
- Removed JR trademark from drop down menu and also from swashplate selection
- Added in cyclic setup instruction "10 degree"
- Minimum and Maximum throttle pulse width for the esc, is visible also in the Wizard
- "Motor is Electric" check now is also in the Wizard, now “Electric motor” is default
- Inserting, complete, correction, of texts.
- Overall optimization and bug fixes (Cyclic Ring, Feed Forward, etc.)
Setting changes to do from previous version :
- Set the new Rotational Speed
- VERY IMPORTANT Verify the cyclic rates separately for ail/elv before flying in each bank
Rates for ail/elev are in Advanced->setup1-2-3->cyclic
Android version will follow in about 2 weeks, we decided to not hold the new firmware and release for windows and have people enjoy it even if Android not out yet.
Please download configuration software from:
http://update.mshbrain.com/Software/BRAINSTALLER.msi
