Nadajnik - Turnigy TGY-i6S
Dział Małego Radiotelegrafisty...
miruuu
Podziękował: 1476 razy
Podziękowano: 706 razy
Postautor: miruuu » 3 sie 2016, o 07:36
To jakiś nowy model czy przegapiłem?
Nie żebym sie nim podniecał, ale być może będzie to jakaś fajna budżetowa alternatywa? hmm
http://www.hobbyking.com/hobbyking/stor ... lack_.html
Features:
• Entry level 6 channel 2.4ghz radio with telemetry capability
• i10 style customized Gimbals with dual bearing supports
• Softer grips for long use times
• 2 and 3 position switches, momentary switches and self-centering proportional wheel switches (2 of each)
• Easy to use touch screen to setup and program the radio
• SBUS and IBUS/PPM support (2 receivers included)
• 5 Model Memory
• Auto trim functions for planes and gliders
• USB and Trainer ports
• Backlit LCD Screen displays real-time transmitter and receiver voltage
• 4 Stick Mode Selection
• Mode 1 and 2 without sprung center stick
• Digital flip flop "Quick Touch" buttons on the back
• Optional telemetry receivers and sensors available separately
• Future firmware updates (Long range firmware)
Turnigy TGY-i6S Transmitter Specs:
Channels: 10 (PPM) or 6 (PWM)
RF range: 2.408 ~ 2.475 GHz
Bandwidth: 500 KHz
RF channel: 135
RF power: Less than 20 dBm
2.4GHz system: AFHDS 2A
Modulation type: GFSK
Stick resolution: 4096
Low voltage alarm: Yes (lower than 4.2V)
DSC port: Micro USB /PPM
Power input: 4.2V - 6.0V
Antenna length: 26mm x 2
Size (Length x Width x Height): 179 x 81 x 161mm
Weight: 410g
Certificate: CE0678, FCC ID:N4ZI6S00, RCM
Turnigy TGY-iA6B Receiver Specs:
Channels: 6
RF channel: 135
RX sensitivity: -105dBm
Power input: 4.0V - 6.5 V DC
Size (Length x Width x Height): 47 x 26.2 x 15 mm
Weight: 14.9 g
Certificate: CE0678, FCC, RCM
i-Bus port: Yes
Data acquisition port: Yes
Pozdrawiam, Mirek
Xeo
Podziękował: 195 razy
Postautor: Xeo » 3 sie 2016, o 08:23
Trochę słabo że na zwykłe baterie jak na nadajnik za 50$
Podziękował: 64 razy
Podziękowano: 336 razy
Postautor: Artu » 3 sie 2016, o 08:37
Jak zwykle zerżnięte z FlySky FS-i6S :masakra:
Xeo
Postautor: Xeo » 3 sie 2016, o 08:47
Do tego już się przyzwyczaiłem
Podziękował: 94 razy
Podziękowano: 125 razy
Postautor: PiotrS » 3 sie 2016, o 08:57
A to nie jest to samo?
Oxy 2, Oxy4, Gaui X3, Oxy 4 Max, Logo 550
Postautor: Artu » 3 sie 2016, o 09:07
A "podróbki" na przykład Aligna to to samo :hammer:
Postautor: PiotrS » 3 sie 2016, o 09:34
Przecież mogą robić rebrand
tak było z reglami hobbywing, ładowarkami niektórymi też
Pan Byku
Podziękował: 79 razy
Podziękowano: 48 razy
Postautor: Pan Byku » 3 sie 2016, o 10:24
Chyba czegoś takiego szukam.
Graupner spoko, multum funkcji, łatwość obsługi, całkiem fajnie leży w łapie, telemetria, ale żebym do każdego "pierdolota", typu Bixler, combat, parkflyer, tanidron, skrzydło, etc., był zmuszony kupować odbiornik za min 150 zł plus koszty wysyłki, to już nie jest tak fajnie.
Szukam właśnie alternatywy i to może być ciekawa propozycja. Co prawda pamięć na 5 modeli tylko, ale do małych gówienek, wystarczy.
Ktoś miał styczność z tym nadajnikiem?
No powiedzcie, że to w dechę pomysł :D
Sie lata.
Pan Buhaj
RC addicted
Xeo
Postautor: Xeo » 3 sie 2016, o 10:28
Dlatego ja mam do 9XR moduł DIY dzięki czemu mogę każdy odbiornik z nim zbindowac
miruuu
Postautor: miruuu » 3 sie 2016, o 13:08
Pan Byku pisze: Co prawda pamięć na 5 modeli tylko, ale do małych gówienek, wystarczy
jak braknie pamieci to mozesz kupic nastepny taki nadajnik w cenie odbiornika Graupnera :)
Nadajnik na pewno nie jest idealny. Mnie bardziej zastanowilo czym sie rozni od klasyki (tgy 9x) i czy to nadajnik ktorego warto polecić komus kto chciałby sobie sklecic styrolota i nie inwestować specjalnie w tą zabawe...
Pozdrawiam, Mirek
Xeo
Postautor: Xeo » 3 sie 2016, o 13:15
Szczerze to chyba bym wolał Tgy 9X Bk w niej przynajmniej masz większe możliwości rozwojowe w sensownym budżecie.
Pan Byku
Postautor: Pan Byku » 3 sie 2016, o 17:57
Tgy 9x jest droższa. Chociażby ze względu na możliwość rozwoju, czy mnogość funkcji. Jednak nie jest zbyt przyjazna i niewygodna.
To maleństwo, za 200 zł, zdaje się być bardzo ciekawą propozycją dla kogoś kto nie potrzebuje wszystkich tych szmerów bajerów, możliwości rozbudowy etc. A właśnie włączyć, zbindować, ustawić podstawowe rzeczy i polecieć. Do tego wygląda schludnie, ma przyzwoite wymiary i obietnice rozwoju softu, czego chcieć więcej? Myślę... Obawiam się tylko o zasilanie. Na ile mogą styknąć 4 paluszki.
Sie lata.
Pan Buhaj
RC addicted
miruuu
Postautor: miruuu » 3 sie 2016, o 20:22
Im mniej ten nadajnik moze, tym byc moze na dluzej wystarcza te paluszki.
Ja mysle tez wlasnie o osobach, ktore nie tyle nie potrzebują tych funkcji co ich nie chca stawiając na prostotę.
Pozdrawiam, Mirek
Wróć do „Aparatury i odbiorniki”
