[S] Hobby Eagle A3 Super 3 A3S3 6 Axis Gyro - 139 zł z przesyłką
miruuu
Podziękował: 1438 razy
Podziękowano: 657 razy
Postautor: miruuu » 10 maja 2018, o 08:42
Sprzedam. Nowy. Standard version.
Cena: 169 159 149 139 zł z wysyłką
Szczegóły: https://www.banggood.com/HobbyEagle-A3- ... rehouse=CN
Overview:
A3 Super 3 (hereinafter referred to as A3S3) is a high-performance and functional 6-axis gyro and stabilizer designed for RC airplanes. This gyro can be used with nearly any size and type of R/C airplanes and it will make the flying even easier and comfortable.
Specification:
Brand Name: HobbyEagle
Item Name: A3 Super 3
Version(optional): Standard Version, Full Set Version (with program card)
Main Controller: 32-bit MCU
Sensors: High-precision 3-axis gyroscope and 3-axis accelerometer
Gyroscope Scale Range: ±2000dps
Accelerometer Scale Range: ±4g
PWM: 920uS ~ 2120uS with 1520uS center length / 50~333Hz
Input Voltage: 4.8V - 8.4V
Operating Temperature: -10℃ - 50℃
Weight: 10g (excluding wires)
Features:
32-bit MCU, high-precision 6-axis MEMS sensor, improved hardware platform and new firmware solution provide more reliable performance.
Supports 6 flight modes, including Gyro-Off mode, Normal mode, Trainer mode, Atti-Lock mode, Auto-Level mode and Auto-Hover mode.
Supports 6-position flight mode switching.
Supports 7 wing types, dual aileron, dual elevator, delta-wing and v-tail supported.
External LED module, integrated with data interface, flat or upright various mounting orientations supported.
Compatible with most standard receivers, standard PPM single-line receivers and Futaba’s S.Bus and S.Bus 2 receivers.
Sub trim and travel limit settings for servos, separate stick Rate and EXP settings for each mode.
Pass-through function for [A2] and [E2] channels.
Customizable hardware and software low pass filters for gyroscope and accelerometer, enable you to optimize the performance of the gyro as you wish.
Quick setup supported by using the programming card while flying outside.
Note:
The Standard Version does not include the program card.
Please select the version you need.
Setup Software V1.0, http://www.hobbyeagle.com/download/A3S3 ... y_v1.0.msi
USB Driver, http://www.hobbyeagle.com/download/CP21 ... ista_7.exe
Online Firmware Upgrade Tool V1.0, http://www.hobbyeagle.com/download/Firm ... tility.msi
English Manual, Click Here
Package Included:
1x HobbyEagle A3 Super 3 6 Axis Airplane Gyro Flight Controller Stabilizer
Pozdrawiam, Mirek
Trex 500X - trex ratio :) | Trex 470LM - cieszy... | Oxy 3 - nie po-byku | Oxy 2 - mały, ale wariat... | Reaktor 3D FPV - drugie życie pianki... | Lizard95 - że też mi się drona zachciało.... | Czesia - jeszcze tylko wyniosę choinkę i się za nią biorę... | LaTrax Rally - kazali mi kupić | Graupner MX-20 - działa
Podziękował: 8 razy
Postautor: gumi » 10 maja 2018, o 19:07
Zamienię na ZYX-S2
miruuu
Postautor: miruuu » 10 maja 2018, o 19:22
Ja zamienię kbara na zyxa s2.
Pozdrawiam, Mirek
miruuu
Postautor: miruuu » 17 maja 2018, o 08:32
Nowa cena: 159 zł z przesyłką
Pozdrawiam, Mirek
miruuu
Postautor: miruuu » 31 maja 2018, o 11:29
149 z wysyłką
Pozdrawiam, Mirek
miruuu
Postautor: miruuu » 15 cze 2018, o 08:31
Dla wincentowców rabat 20% do końca tygodnia :)
Pozdrawiam, Mirek
miruuu
Postautor: miruuu » 22 cze 2018, o 16:07
Nowa cena: 139 zł z wysyłką
Pozdrawiam, Mirek
Podziękował: 150 razy
Podziękowano: 58 razy
Postautor: omcKrecik » 25 cze 2018, o 23:23
Mój praszczur miał na imię Wincenty... Więc się załapuję, tydzień właśnie się zaczął :mrgreen:
