kris pisze:A z tymi modułami DSMX do innych aparatur to rzeczywiście jest problem. Sam chciałem kupić taki moduł do mojego Taranisa, ale okazało się, że ich nie ma.
Hello. Can I connect this module to the Flysky FS-i6X transmitter? Will it work?
not really without heavy modification the fs-i6x doesn't have a Jr bay. There are 3d printer stls online to help and you would have to do some wiring and soldering along with a step down transformer. Even then you wouldn't be able to use the serial function without open tx just the ppm
