F3C is the category assigned by the FAI (The World Air Sports federation) for precision helicopter aerobatics.
Here's a list to get you started - each topic can be as deep a rabbit hole as you'd like.
The mechanics were all set to the Align manual recommendations for F3C. It is important to work on the heli so it will hover hands free in calm weather.
menelique pisze:Pozwole sobie pododawac kilka linkow, ktore wpadly mi w rece przy okazji przeczesywania internetu w poszukiwaniu informacji o F3C.
W miare postepow, bede aktualizowal tak by nie robic lancuszka postow.
0. Samo F3C slowem wstepu.F3C is the category assigned by the FAI (The World Air Sports federation) for precision helicopter aerobatics.
In F3C, pilots must perform complex hovering and aerobatic manoeuvres.
Each manoeuvre must be executed with high precision and skill in any attitude and under all weather conditions.
F3C comprises of 2 set schedulesThe Preliminary (P) Schedule
and the more complicated Final (F) Schedule.
http://www.theaha.co.uk/f3c.html
Kilka filmow YT
https://www.youtube.com/watch?v=AR1dhR7RjH4
https://youtu.be/eIi_tk2Zhss
https://www.youtube.com/watch?v=lUn4jvKfhAs
https://www.youtube.com/watch?v=d1WzzqrmkHo
1. F3C a dokladniej wariant SPORTSMAN (5.4.3)
"Ever wanted to have a go at F3C Style flying?
Why not try the Sportsmans class first?
This is an excellent way to learn the basics and slowly progress into F3C using a modified schedule."
http://www.helinats.co.uk/european_sportsmans_helicopter.pdf
2. Brian Byrdman - inspirujaca postac
Najpierw krotki wstep: https://www.helidirect.com/blogs/news/how-i-got-started-f3c-precision-flying
A nastepnie wystep w podcascie(!): https://rchnv3.podbean.com/e/rchnv3-ep21-so-you-want-to-f3c/
Oraz jego kanal YT: https://www.youtube.com/@bbyrdsong
3. Forum helifreak a dokladniej dzial latania Contest / F3C
Tutaj czytania co nie miara, fajne do poduszki.
https://www.helifreak.com/forumdisplay.php?f=61
4. Technicznie
Czyli znalezione informacje odnosnie konfiguracji / setupu do F3C.
Tu jeszcze sie rozgladam, dlatego poki co wersja WIP.
Jaki model pod F3C (cytuje Briana Byrdsonga z Podcsatu powyzej):"Nothing less than 600, you need a nice decent size heavy bird to give you the nice, stable hovers"
"Doesn't need to be a fuselage Bird"
"Good set of F3C Main Rotor Blades, these are very important as the center of gravity is more towards the ends, and more forward on the core - which gives a night stable hover"
"Doesn't matter the brand of the Heli, Doesn't matter the transmitter"
"Hover head speed anywhere 1300 - 1450 rpm"
"Aerobatics 1850 - 1950"
Setting up for F3C: https://www.helifreak.com/showthread.php?t=252194#post2447028Here's a list to get you started - each topic can be as deep a rabbit hole as you'd like.
F3C "noob" setup: https://www.helifreak.com/showthread.php?t=394094The mechanics were all set to the Align manual recommendations for F3C. It is important to work on the heli so it will hover hands free in calm weather.
Po 15 latach można śmiało założyć że zaczynasz od początku...
- 2 hover figures + 5 aerobatic figures and landing.
- 3 hover figures + 4 aerobatic figures and landing.
- 4 hover figures + 3 aerobatic figures and landing.
Wodzu pisze:Największym problemem w rozegraniu zawodów F3C lub podobnych jest brak sędziów , no i oczywiście zawodników. Z tego powodu od dobrych kilku lat nie ma PP i MP w klasach F3C i F3N. Były nawet w Polsce MŚ heli, chyba w Inowrocławiu, w których nie startował żaden Polak. Z kolegą „Sulim” próbowaliśmy wskrzesić temat, ale na razie nie udało się. Może teraz…? Jest jeszcze paru „starych” helikowców, którzy wiedzą o co chodzi.
aikus pisze:Nie no zara zara....
To że ja napisałem Wincentów i Racibórz, to nie znaczy, że tylko te dwa zloty w Polsce się regularnie odbywają, to po pierwsze, po drugie, tylko pierwszy z nich jest typowo helikopterowy, na drugim helikoptery zawsze były w niedostatku, ostatnimi czasy zaczyna się to trochę zmieniać.
Jest jeszcze Świdnica, Zagaje, Wilcze Łaski....
Zajrzałeś do działu który podlinkowałem?
Każdy z tych zlotów byłby IMHO dobrą okazją do próbowania tego zrobić, Racibórz akurat najmniej.
A czy znajdzie się dostateczna ilość chętnych - tego nie wiem.
Mógłbym pisać o moim stosunku do sprawy, ale to się raczej mija z celem.
kris pisze:Czy ktoś ma może jakis link do filmu z lotu programu A?
A jeżeli nie, to może ktoś, kto zna ten program mógłby taki filmik nagrać? Może być na zywo lub z symulatora.
Nie jestem pewien niektórych szczegółów (np. czy A5 i A10 to taki sam stall turn? Jak wygląda A7 itp.)
Zybidk pisze:W tym roku w wincentowie chcemy zacząć ściągać ludzi do F3C. Jest już oficjalnie na fb podany program A do próby zorganizowania większych zawodów. Jak się znajdzie więcej osób to w przyszłym roku beda większe zawody. Póki co sędziów mamy starych wyjadaczy w F3C. Można ćwiczyć już i spróbować swoich sił w czerwcu. W dziale imprezy krajowe i zagraniczne jest utworzony post odnośnie f3c wincentow.
