Goblin 500
Podziękowano: 239 razy
Postautor: PiotrS » 28 sie 2015, o 19:27
Dostałem dziś takiego maila:
All New Kits via SAB!
Furthering the dominance and performance of the Goblin line, the team at SAB is introducing an entirely new lineup of Goblin kits that capitalize on performance, value, and the beautiful aesthetics that has made Goblin helicopters the most recognized helicopter on the market today.
From the Goblin 380 to the Urukay edition, SAB has taken a close look at each kit - revitalizing and improving, all the while reducing costs of each and every kit. Updated and improved, these lower costs kits will allow even more pilots to take hold of the SAB brand name, furthering the dominance of the Goblin name.
Available for pre-order now, be sure to place your orders quickly for this new line of SAB Goblin kits, as these new models will move as fast as they look!
SAB Goblin 500 Sport - New Look, Lower Cost, Amazing Performance.
Utilizing 85% of the part from previous Goblin 500 kits, the all new SAB Goblin 500 benefits from a strong industrialization of the Goblin line, reducing the weight and cost of this model, all the while adding only (7) new parts to the mix.
With a strong resemblance of the wildly popular Goblin 380, the Goblin 500 Sport has been updated on multiple fronts, improving weak areas, and adding a whole new aesthetic appeal to the aircraft itself.
To further benefit new Goblin pilots, SAB has introduced an all new pre-packaged combo kit, providing incredible value into the Goblin lineup. This will not only allow SAB to compete on a cost level, but will open the doors to entry level pilots looking to purchase their very first high performance SAB kit. Further this value with (2) sets of main rotor & tail rotor blades with combo and non combo kits, the sweetness factor ramps up that much more when it comes to making a purchase with SAB.
Tried and true, the SAB Goblin 500 has been infused with an all new look and design. Coalesce these changes with new combos, high quality electronics, and an all new lower price point, and you have a potent mix of performance and affordability few can pass up.
Release Date: October 14th, 2015
Features:
- All New Aesthetic Design
- Lighter, Stronger, Lower In Cost
- (2) Sets of Main & Tail Rotor Blades
- Combo Packages Available
- 85% Parts Compatibility
Combo Components:
(3) KST DS589MG Cyclic Servos / (1) KST DS525MG Rudder Servo
(1) Quantum 4020-1200 High Performance Brushless Outrunner
(1) High Performance HobbyWing Platinum 100A V3 ESC
Pricing - Combo Kits:
SG509 - Goblin Sport Combo Kit / White: $875.00
SG510 - Goblin Sport Combo Kit / Yellow: $875.00
Pricing - Non Combo Kits:
SG507 - Goblin Sport Kit / White: $609.00
SG508 - Goblin Sport Kit / Yellow: $609.00
Postautor: Jazz » 28 sie 2015, o 19:51
Szkoda że nie ma combo bez serw, bo nie chce tych KST (wolę BK ktore sa mocniejsze, 3 razy szybsze)
Także chyba ide w kit :-)
Postautor: Kenobi36 » 28 sie 2015, o 20:06
A niech to, belkę skreciłem 2 miesiące za wcześnie ;-)
Postautor: Jazz » 28 sie 2015, o 20:26
85% części kompatybilne z aktualna wersją G500, w zestawie dostajemy 2 komplety łopat głównych / ogonowych.
Wybór kolorystyczny ubogi - zamawiaj Kenobi biało-czerwonego dla mnie :-)
Co do silnika z wersji kombo - z tego co czytalem gdzieś wczesniej to miał byc quantum 4115 1200 kv, a takeigo jak podali nie ma w ofercie , jest 4120.
Postautor: wojtekr » 1 wrz 2015, o 17:03
Jakie kąty macie w G500?
Postautor: Kenobi36 » 1 wrz 2015, o 18:09
13.8
12 na cyklice
Postautor: wojtekr » 1 wrz 2015, o 19:54
A to jest jakiś Twój hardcore czy ten model powinien mieć takie duże kąty?
Postautor: Kenobi36 » 1 wrz 2015, o 20:04
Kątów i obrotów nigdy za mało :-)
Danielus
Podziękowano: 42 razy
Postautor: Danielus » 5 wrz 2015, o 11:53
Poniżej przedstawiam zdjęcia konwersji na trzy łopaty do Goblina 500.
Może w poniedziałek wykonam oblot. Jutro dalszy ciąg zdjęć.
Extra330
Postautor: Extra330 » 5 wrz 2015, o 16:16
dasz popatrzyć?
Pozdrawiam Władek
Gaui X2, X5, X7, MX3
Goblin 420, 500HPS3, 700C
Postautor: Don Mirson » 5 wrz 2015, o 18:46
Czekam na fotki na modelu. Musi wyglądać apetycznie...
Postautor: Kenobi36 » 5 wrz 2015, o 19:22
To teraz outbox poprosimy :-)
Postautor: PiotrS » 6 wrz 2015, o 11:58
Wczoraj wieczorem zmieniłem ubranko mojego Goblinka :)
Od razu lepiej mi się nim zaczęło latać ;)
Postautor: msheli » 6 wrz 2015, o 12:06
Jak dobrze zobaczyć goblina w innych odcieniach... :)
Bradzo ładnie to wygląda ;)
Wysłane z mojego GT-I9505 przy użyciu Tapatalka
Postautor: Don Mirson » 6 wrz 2015, o 12:26
Fajnie fajnie... ale chcę obejrzeć na żywca :)
Postautor: PiotrS » 6 wrz 2015, o 12:32
To trzeba na Pałacową było przyjechać ;)
Postautor: Kenobi36 » 6 wrz 2015, o 20:36
A zważyłeś belkę i porównywałeś do karbonowej przed założeniem?
Postautor: PiotrS » 6 wrz 2015, o 21:07
Szklana cięższa o 7 gram
Danielus
Postautor: Danielus » 6 wrz 2015, o 21:35
Czas na montaż.
Zaczynam od tarczy, pierw kontrola śrub skręcanych fabrycznie. Wszędzie był klej.
Pozostaje jeszcze tylko wkręcić kulki i gotowe.
Nowa tarcza bardzo mi się podoba bo jest masywniejsza i kulka jest stalowa, a nie aluminiowa jak we wcześniejszych.
Biorę się za głowicę. Na początek postanowiłem sprawdzić montaż szpindli.
Tu również wszystkie śruby były wkręcone na klej.
Kolejny krok to montaż ramienia antyrotacyjnego.
Bardzo ważna podkładka, dzięki niej kołnierz łożyska nie będzie ocierać o głowicę.
Ramie gotowe, więc montuję dampery, oczywiście gumowe oringi muszą być posmarowane smarem sylikonowym.
A taką zawartość ujrzymy po otwarciu woreczka z okuciami.
Pierw przykręciłem ramiona okuć, później kulki.
Zabieram się za łożyska , jedno maszynowe te od strony głowicy było zamontowane, ale resztę trzeba założyć samemu.
Oto jak łatwo odróżnić, która bieżnia łożyska oporowego jest która.
W zestawie jest jeszcze dodatkowa podkładka, której nia ma na zdjęciu, a którą można usztywnić głowicę.
A tak wygląda całość.
Postautor: Kenobi36 » 7 wrz 2015, o 18:08
Wreście zaczeli dawac stalowe kulki.
Długo do tego dochodzili :masakra:
Chociaż chyba w g380 też jest stalowa.
Jest to jedyny mankament jakościowy jaki mam w goblinach.
Kulka w plastiku się wyciera. Co ciekawe na wale luzu nie ma, tylko od obracania w plastikowym gnieździe się wyciera. Aż dziwne że na HF nikt o tym nie pisze. Dawanie smaru nic nie daje bo chyba się robi papka ścierna :masakra:
W 700 już zacieśniałem plastikowe obejmy. A w g500 nie długo kulka z tarczy mi wypadnie :-)
Chyba będę dorabiał bo raczej nigdzie nie dobiorę, chyba że z zestawów naprawczych lynxa.
Wróć do „SAB Goblin”
