Nie żebym sie nim podniecał, ale być może będzie to jakaś fajna budżetowa alternatywa?
http://www.hobbyking.com/hobbyking/stor ... lack_.html
Features:
• Entry level 6 channel 2.4ghz radio with telemetry capability
• i10 style customized Gimbals with dual bearing supports
• Softer grips for long use times
• 2 and 3 position switches, momentary switches and self-centering proportional wheel switches (2 of each)
• Easy to use touch screen to setup and program the radio
• SBUS and IBUS/PPM support (2 receivers included)
• 5 Model Memory
• Auto trim functions for planes and gliders
• USB and Trainer ports
• Backlit LCD Screen displays real-time transmitter and receiver voltage
• 4 Stick Mode Selection
• Mode 1 and 2 without sprung center stick
• Digital flip flop "Quick Touch" buttons on the back
• Optional telemetry receivers and sensors available separately
• Future firmware updates (Long range firmware)
Turnigy TGY-i6S Transmitter Specs:
Channels: 10 (PPM) or 6 (PWM)
RF range: 2.408 ~ 2.475 GHz
Bandwidth: 500 KHz
RF channel: 135
RF power: Less than 20 dBm
2.4GHz system: AFHDS 2A
Modulation type: GFSK
Stick resolution: 4096
Low voltage alarm: Yes (lower than 4.2V)
DSC port: Micro USB /PPM
Power input: 4.2V - 6.0V
Antenna length: 26mm x 2
Size (Length x Width x Height): 179 x 81 x 161mm
Weight: 410g
Certificate: CE0678, FCC ID:N4ZI6S00, RCM
Turnigy TGY-iA6B Receiver Specs:
Channels: 6
RF channel: 135
RX sensitivity: -105dBm
Power input: 4.0V - 6.5 V DC
Size (Length x Width x Height): 47 x 26.2 x 15 mm
Weight: 14.9 g
Certificate: CE0678, FCC, RCM
i-Bus port: Yes
Data acquisition port: Yes
