Turnigy K-Force 120A HV PRZESTROGA! SPALONY!
Postautor: AdamskY » 26 maja 2011, o 20:35
YGE Brushless Controller i np cenny ---------> RC-Now ja wiem czy to dużo tańsze niż Kontronik?
a co powiecie na temat tego ESC i jego ceny (EUR 84,19)?
Hobbywing Platinum 150A pro ESC Brushless
albo ten New Hobbywing Platinum 120A HV Pro 600 700 helicopter EUR 115,40 z darmowa wysyłką :)
Platinum-120A-HV-PRO ESC belongs to Hobbywing's "Platinum" series products line, it is the most significant top-class product for aircraft and helicopter.
1 Typical Applications
1.1 Super powerful for 600 class helicopter (Working with 8 or 10 cells Lipo battery)
1.2 Very powerful for 700 class helicopter (Working with 10 or 12 cells Lipo battery)
1.3 Super powerful for large scale aircraft such as F3A
2 Specification
2.1 Output: Continuous 120A, burst 180A up to 10 seconds.
2.2 Input Voltage: 5-12 cells lithium battery or 15-36 cells NIMH battery.
2.3 BEC: None.
2.4 Control Signal Transmission: Optically coupled system.
2.5 Max Speed: 210,000rpm for 2 Poles BLM, 70,000rpm for 6 poles BLM, 35,000rpm for 12 poles BLM.
(BLM: BrushLess Motor)
2.6 Size: 88mm (L) * 55mm (W) * 15mm (H).
2.7 Weight: 125g.
3 Features
3.1 High performance microprocessor brings out the best compatibility with all kinds of motors and the highest driving efficiency.
3.2 Wide-open heat-sink design to get the best heat dissipation effect.
3.3 With 3 types of start mode: Normal / Soft / Very-Soft, compatible with aircraft and helicopter.
3.4 Smooth, linear, quick and precise throttle response.
3.5 Multiple protection features: Low-voltage cut-off protection / Over-heat protection / Throttle signal loss protection.
3.6 The throttle signal is transfered through optically coupled system to avoid the electromagnetic interference.
3.7 Perfect governor mode for helicopter.
3.8 The firmware of the ESC can be updated through the USB adapter on the Professional LCD Program Box.
3.9 User programmable. Several kinds of program methods are supported: transmitter, digital LED program card, advanced professional LCD program box, PC software. Very easy to program the ESC at home or at the flying field.
Podziękował: 313 razy
Podziękowano: 294 razy
Postautor: Ramotny » 26 maja 2011, o 20:47
no właśnie taki sie Sebusiowi zjarał... tyle że nie jako HobbyWing tylko Turnigy.
Postautor: edek » 26 maja 2011, o 21:14
Ale HW sie nie pala :lol:
Postautor: AdamskY » 26 maja 2011, o 21:28
edek pisze:Ale HW sie nie pala :lol:
jak będą miały naklejkę GAUI to się na pewno nie będą palić :vhappy:
Postautor: tomek68 » 26 maja 2011, o 21:43
Co tu dużo gadać jedyny heli stoi dla pewności na szafie aby mu się co nie przytrafiło :vhappy:
[youtube]http://www.youtube.com/watch?v=YKzpQnKgdEc&feature=related[/youtube]
Ciekawe czemu komentarze zablokowane :roll:
Postautor: edek » 26 maja 2011, o 23:17
AdamskY pisze:
Na bank.
