WLtoys - V955
Postautor: Don Mirson » 7 sie 2015, o 11:06
To chyba najtańszy helik 6 kanałowy na rynku (25$ RTF na hobbykingu).
Wziąłbym, gdyby nie taki mały detal... że ten 6 kanałowiec jest 4 kanałowy... ;)
WL Toys V955 Sky Dancer CCPM 6 Channel Flybarless Helicopter Ready to Fly 2.4GHz
The V955 is a six channel collective pitch flybarless helicopter and is an fantastic introduction to collective pitch 3D helicopters packed into a miniature ready to fly package.
The V955 is equipped with a 3-Axis gyro that assists the pilot in flight stability. The flybarless rotor head is designed with weighted main rotor blades for additional stability while the flybarless systems allows the CCPM rotor head to be kept simple for trouble-free set up and repair.
A unique feature of the V955 ability to flick the "Easy Control" switch located on top of the transmitter to enable the orientation of the helicopter to remain as normal when flying inverted, avoiding the usual problems associated in this situation. Some folks might think that this is cheating, in which case you can leave the function alone and fly the V955 as normal using the idle up switch.
The 6 channel 2.4 GHz transmitter has an easy to read LCD display and may be switched between stick modes by using the slider on the front of the case.
The V955 is suitable for inexperienced and experienced heli flyers alike and will not disappoint with its responsiveness and aerobatic abilities.
For those with experience and flight time with Co-Axial and Single Rotor Head helicopters it is an ideal progression into the world of collective pitch helicopters.
Features:
3D capable
• 3-Axis gyro control system
• Flybarless rotor system
• Automatic power-cut protection system
• 6 Channel 2.4 GHz transmitter with built-in LCD display
• "Easy Control" switch for inverted training
• Battery charger included
Specs:
Length: 200mm
Height: 80mm
Rotor dia: 204mm
Weight: 35g
Range: 80-100m
Battery: 3.7V LiPoly (1s 180mAh)
Package includes:
1 x WLToys 6CH V955 Flybarless Helicopter
1 x 2.4G 6CH Transmitter w/ LCD Display
1 x USB Charger
2 x LiPoly Battery for Helicopter
1 x Set of Spare Main Blade
1 x Spare Tail Blade
1 x Spare Accessory Pack
Required:
4 x AA Batteries for Transmitter
Gajos
Postautor: Gajos » 7 sie 2015, o 11:50
On chyba słabiutko lata, ma szczotkowy silniczek... :(
Postautor: przemek » 7 sie 2015, o 13:42
Jak HK machnie sie w opisie, to sie do nich odsyla zeby kase oddali, czy oddaja bez odsylania? :) Przerabial ktos podobny temat?
