MacGyverek pisze:Hehe... A jak w 3gx chcesz ustawić orczyki jeśli są lekko nie w poziomie? Nawet w instrukcji 3gx o tym piszą. Był wątek na forach o tym.
Odległosci w snapach od orczyków ustawione idealnie jak podaje instrukcja 10.5 mm ,
moge nimi pokrecic ale wtedy ta dolna tarcza nie bedzie w poziomie .
Serio ten system jest tak trudny??? Mam Beastx-a i praktycznie nic z tych rad, co tu opisujecie,wcale nie robię
J. Teaching the Cyclic Pitch Geometry
CAUTION: Do not touch any stick on your transmitter when entering menu
point (J). This will cause unwanted flight behavior.
1. Move the rotor blades so that they are parallel to the tail boom.
2. Attach a pitch gauge to a rotor blade. The swashplate should be in the neutral
position and the blade should have 0° of pitch. If the swashplate is not
neutral with 0° of blade pitch, repeat menu point (G) before proceeding.
3. Move the aileron stick left or right until the pitch gauge has exactly 6° of
cyclic pitch.
IMPORTANT: The Status LED should still be Blue at 6° of cyclic pitch. If the
Status LED is Red, Purple or Off, you must mechanically adjust the helicopter.
You can use:
A.) Shorter servo horns
B.) Shorter linkage balls on the inner swashplate ring or
C.) Longer blade grip linkage levers
4. If the pitch gauge has more than 6° of cyclic pitch, move the aileron stick in
the opposite direction until the pitch gauge is at 6°.
5. Release the aileron stick and press the setup button once.
